Daylight Savings Time, Do you update all devices?
How do you deal with Daylight Savings Time on plant equipment?
  • Total voters
    27
Sliver
Feb 2004
Kingston, Ontario
488
To all you plant maintenace guys and gals.
As more and more plant equipment has fault logging and time stamping, how do you deal with Daylight Savings Time?
I leave the PLC clocks alone.
The Windoze HMI clocks - which is where the alarm and data logging occurs - change automatically.
It depends on the application. On occasion we use the clock to anticipate traffic demand, so there's code in the program to change the PLC clock to Spring Foward & Fall Back...
I've have it set up on our PM program to capture the current program on each PLC (and update the Time) on the date we go to or from DST. Works well for me--maybe not everyone.
I would have to vote none of the above. All of my PLCs are updated with the correct time every five seconds by the main server. In fact, every computer on the network is in synch, which helps a lot if I have to look at time-stamped messages.
I'm not sure how it is with other PLCs, but this is pretty easy to do on the S7 platform.
S7Guy said:
I would have to vote none of the above. All of my PLCs are updated with the correct time every five seconds by the main server. In fact, every computer on the network is in synch...
I have just received an email at work from the IT people apologizing for some confusion caused by the server changing its daylight savings time a week early....
[The change back to normal time in parts of Oz was delayed to fit in with the Commonwealth Games..]
We change so that the production logs are correct. The operators start crying when their production is credited to a different shift.
We have a client with 24/7 operations with batch reports that include queries of process values from an FT Historian. They do the reports in SQL...
1,508
Finishing up my first project with a Do-More PLC to install tomorrow morning. I'm working on small details.... like automatically adjusting for...
1,880
Using GSV WallClockTime and LocalDateTime, when I check the box "adjust for Daylight Savings" it advances the time by one hour. What is the...
6,423
Hello I have four slc 505 processors on an ethernet/IP network. I would like to be able to change the time and date in only one of the processors...
2,230
I searched for an example of how to adjust for daylight savings time, but I could not find one anywhere. So after considerable thought and time...
19
11,127
