delta dvp sa real time clock
bfnm
Jan 2010
bloemfontein
Hi All, anyone here that can help me to program this plc in terms of its real time clock?
i need to rotate three outputs on a weekly basis.
if i have to i'll use a normal timer but there must be an easy way since the plc does have a rtc.
i have downloaded the manuals and all but seems i am still two much of a novice.
tx
hi, can i mail you a ladder diagram that was write with Delta wplsoft. me and my friend programme it for my home controlling 4 watervalves.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
51
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,923
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,345
Hi all! I need help help with my delta module. Model : DVP-06XA-S Firmwire : 4.08 When i was setting my Rs485 parameter i...
914
Hello, someone know how to configure this PLC (DELTA DVP-14SS2) In the COM2 modbus RTU 485 baud rate 9600 8E1 slave mode (Not the plc Link)...
1,475
