Delta HMI vs Micrologix 1400
Relentless1
Oct 2019
Quebec
Hello,
I want to connect a Delta DOP-107BV to a Micrologix 1400. Would a DOP-FX cable do the trick?? https://www.ebay.com/c/849453778 I dont think it's the same pinout for Allen-Bradley...
The cable I have right now is connected to a TouchWin HMI and a mitsubishi fx3ga-40mr. Maybe I can just modify the pinout on this one??
Thanks!
http://www.delta114.kr/board/filedown.php?ogfile=12385739100.pdf&filename=DOP-HMI_connection_en.pdf
The above link will take you to the connection manual.
Page 1-16 will show you the pinout.
You will probably have to make your own.
https://www.plccable.com/
These guys might have something on the shelf.
I hope this helps you out.
Regards,
Thanks Garry, I was reply to the thread when I saw your reply
I would contact Delta and see if they can provide the pinout of the HMI, you are correct when you say the China cable will not work... now that Garry replied, see the link for the pinout and if you can find a Mini DIN 8 you will need to connect to 2/3 and 5, 5 being your ground/comm and 2/3 being TX RX on the 1400
Best of luck
Mark (AKA GiT)
Hello, I'm trying to send recipe from my Delta HMI to Micrologix PLC. With Delta PLC, you would use ''D'' variablews to send Float, Srtring. Anybody knows how this would work for a Micrologix PLC??
Hello, I'm trying to send recipe from my Delta HMI to Micrologix PLC. With Delta PLC, you would use ''D'' variablews to send Float, Srtring...
1,786
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
Hi, We have a customer that has an old DOP-A80THTD1 that is needed to be upgraded Can we upload from these units? Is there a special...
99
Hello, I know little English, I want to use 4 plc cqm1 as slave (modbus), and hmi delta as master. Unfortunately, I cannot establish rs485...
592
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
576
