Delta PLC UP ZP connection
domyplc
Jun 2019
UP
Hi all, I have Delta 12SA2 11T transistor type plc and I am confused about the output wiring, A video on youtube : https://www.youtube.com/watch?v=8kW9AwN2fs4 says that we can connect UP to +24V and ZP to 0V for sinking outputs (NPN wiring) figure1 and the reverse i.e., connect UP to 0V and ZP to +24V for sourcing outputs (PNP wiring) figure2, please see the img.png attached here with. (image link : https://drive.google.com/open?id=1idegjXoAQ-Vmu4zMeCWN1PPWUMB-WgaS)
open
The first one is working ok but the second one not, when i connect UP to 0V and ZP to +24V for sourcing outputs (PNP wiring) figure2 then my indicator remains always ON no mater i trigger the output on or off
The manual says that the PLC only has NPN transistors in the output inside the plc then how he in the video is showing both ways.
Please help me to understand this.
Thanks in advance.
Hi! I'm an intern and a newbie in the field of automation. I was given the assignment to learn and program a PLC and HMI together. PLC: Delta...
1,986
Hi guys, I have a server with a specific ip. Can i check the connation for that ip using the DELTA PLC?
718
Hi all, this a good community to join with, I would like to know how to make connection between DELTA PLC with Model: DVP-12SA2 to VFD DELTA S1...
3,346
needed little help with the connection of VFD and setting its parameters. Delta series B VFD (3 phase, 2.2 kw) used to vary the speed of...
6,054
Hi Friends, I have CPU315 2PN/DP configuered as shown in the images attached. It is connected through profibus network to PC477 & which acts as...
2,918
