Derived Tags In Wonderware?
chrisj91
Nov 2010
England
33
I was wondering if Wonderware has anything similar to FactoryTalk's Derived Tags? I'm new to Wonderware and am more used to FactoryTalk's setup so I was wondering if Wonderware had anything along the same lines?
So, just to be clear, I want to be able to have a tag which uses an expression which contains other tags.
(eg, I want Time_Left to have the expression using two other tags: Preset_Time - Accumulated_Time)
Hope this makes sense,
Thanks in advance
Anybody. . . . ? ?
attachment.php
I believe you would have to make a memory tag, then use either a condition script or data change script to calculate those values and write them to the memory tag that you made.
Brilliant!! Thank you, I shall give this a go.
It sounds right when it's told to you but isn't it weird how you just sometimes can't think of it yourself? šŸ™ƒ
Thanks for the help diat150 :)
I was wondering if I could set up In touch to pass one tag from one plc to another plc based on the tags in wonderware. Factorytalk derived tags...
3,034
I have a project I have ported from RSView32 to Factorytalk View SE running on a computer. The software is talking to 5 remote plc's over 900mhz...
2,296
Hi, I am trying to set up a derived tag that gets its state from an expression looking at a number of very similar Tag Names, eg all start with...
1,586
Hello Everybody, I'm having a problem with derived tag in FactoryTalk View Studio v5.00. I created a new derived tag file, and the following...
2,321
Hi guys! I have a problem with derived tags in factorytalk view. I used the derived tags to read an input tag (unit in seconds), and convert it...
2,047
