Prince
- Join Date
- Jun 2002
- Posts
- 284
Regarding a project, I am to identify different pipes from each other and save the test reports in a database.
For now, we are using a semi-Automatic system in which the system guesses the pipe number for the pipe being tested at each station and an operator check the number with the number written on the pipe wall then he has the ability to confirm or edit the number.
We found that It would be a deal of luck if we can initialize a system to detect the pipe number without the need for an operaor supervsion.for that we need a detection system capable of identifying the number of a pipe. We can not use the normal bar code system cause the pipes rotates and move a lot in conveyors. so it would be hard to find the place that the pipe has been marked on.
I wondered if somebody had the same problem and can suggest me a way out of the mess.
