Determining Address to be used of Advantys when the are slave of Quantum CPU 651 50
reymond_craig
Sep 2007
Manila
I got this problem, I cann't find a manual that would tell what should be the address of my i/o located on advantys which is connected to Quantum plc through modbus tcp or through NOE 771 01.
Please help me to solve this problem.
Thank you very much in advance.
Set the rotary switches on the Advantys ethernet (nip) module to a unique address for each rack. (first rack may be 01 so set top switch to 0 and bottom switch to 1). Then use the DHCP server on the quantum noe module to set an ip address for STBNIP2212_001. Use the io scanner in the noe module to scan that ip address into local memory. Have a look for the advantys hardware manual and it will show you the mapping for each card, ie the number of input registers and output registers used by that card. There are two arrays of registers in the nip -
the input image starts at 45392
and the output image starting at 40001
try this manual for more info
http://www.summit.com/markets/autom...tandard Ethernet Modbus TCPIP NIM NIP2212.pdf
or this one for the hardware
http://conecta2.schneiderelectric.es/nbd-update/cont2/31002952_K01_001_02.pdf
I have my PLC and HMI connected to my local network over DHCP just like my laptop. I can upload and download including VNC to the HMI over wifi...
1,144
We are in the process of installing a new DC drive to replace a 1373 series Speedpak drive. There are 8 leads coming out of the motor -- Two for...
856
Good morning! I am looking for a clever method to determine the number of occurrences in a series using ladder logic. What I need to determine is...
1,267
We have a DC Drive (ABB DCS800) which is running a load (initially) at a fixed speed. For testing purposes, we want to simulate a different...
20
6,325
ive been tasked, due to a restructure of our inventory, to find out how big our SLC programs are. specifically, we have several dozen 5/05s at...
1,736
