Devicenet File
jashwa
Aug 2013
Beloit, WI
I am currently working on a project were I need to make some changes to a compactlogix system. My company did not originally install the PLC and it has a scanner for devicenet. I am not very familiar with devicenet and wanted to make sure that if I uploaded the program made my changes then downloaded it back to the controller I wouldn't have any issues with the scanner configuration.
Josh
Hi Josh
The simple answer is yes but there never is just a simple answer.
First
If all the items are Allen Bradley then it's easier. You can just go online scan the network and when you are happy that you can see all the nodes you can right click on the page and upload from all devices.
Now if you are adding a new node then you just wire up
Your new node set a node address not already used and less than 62. Rescan your network and it should now be there, go to you scan list map it across and set up your I/o in the input and output tabs, download to the card and it should work as long as you get the correct amount if input and output bytes.
It is a little it different if it's not an Ab part but let us know and we can cross that bridge if needed
Donnchadh
The Scanlist configuration is stored in the 1769-SDN DeviceNet scanner itself, and the configuration of the network slave devices is stored in their memory.
So an upload of the CompactLogix controller program itself won't affect the DeviceNet configuration at all.
As has been mentioned, if you need to configure the DeviceNet scanner or something on the network, you're going to need RSNetworx for DeviceNet software.
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
110
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
712
Does anyone have the ability to convert old Devicenet Manager files to a usable RSNetworx file? I understand there was a conversion tool included...
1,220
Hello fellow programmers, I am looking for a DeviceNet file with at least 1 VFD (powerflex70 and 700 if possible) and 1 E3 for parameter review...
1,402
Can anyone help me find the .eds file for a Siemens Devicenet module, P/N: 5136-DNS-200S Revision 2.004? I tried using "Download EDS file" in...
6,301
