DeviceNet node limits
Buck Bonzai
May 2007
SC
I'm new to DeviceNet and understand you can have 64 nodes on a network, leave 0 and 1 for scanners, 63 is for new unaddressed nodes but I was wondering if there is a general rule of thumb to how many nodes you can should have on a network? I've been hearing around 40.
The maximum numbers of nodes I have installed are 20, however i have not heard of practical limitations.
In other of my installations the scanner is number 63 so it is not true that the scanner has to be 0 or 1.
It's really 63 because you do not want to set any of your nodes to 64. When you install a new device that is not dip switch settable it will automatically show up on 64 until it is configured so you don't want something permanently on that node
The limit also depends on what devices you have on the network you have all DSA's you could have 63 DSA's, but if you had a lot of Powerflex drives with all the Datalinks enabled you would fill up your scanner pretty quick.
Your description is close to being correct.
There are 64 nodes TOTAL, numbered 0 through 63. New devices generally default to node 63 so that is the one to wisely leave available. FYI, I think it's wise to make the scanner node 0 since you always need that... Other nodes may change and adjustments can be made to accommodate those changes.
here is some of Phils articles on devicenet and other configurations I've been placing them into one file for easy reference found it very useful that way
I do not know about other brands but I believe the Omron Device Net scanner is limited to 300 words so you have to be careful how many words are allocated to a module as well as the physical limit of 64. Expicit messaging to some devices on a network will release quite a lot of words but does slow down the communications somewhat.
Howdy Everyone, We have an old ternary drive from Wittenstein it is a TXBA046AAQ, i got the EDS file so i can add it to RSNETWORX for devicenet...
734
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,039
Hi, Did anyone succeed to send an explicit message to a Devicenet node? The official UDFB RA_DNET_EXPLICIT is not compiling. According to...
1,423
Hello, anyone really good with devicenet protocol? I've been troubleshooting an issue with a certain node on a network going down but recovering...
1,905
Hello forum members, We are having a frustrating issue (yet again with my favorite network - Devicenet). We have an ABB robot that works with an...
4,033
