Devicenet Problem
Mar 2015
milan, mi
34
We have a 1769-sdn scanner that is giving me a lot of problems. Last week node #2 ( 1738-adn12) had a short in the card. I replaced the card, repaired short, and it was still flashing red ( pointbus status light ) . I went online with rsnetworx for devicenet. I was able to go online, upload the program. It says node #2 not initialized, but the others nodes are. I checked the scanlist, inadvertently I pulled off everything from the scanlist and put back into available list. I quickly realized my mistake and put them back into the scanlist and then downloaded back into the scanner. Then I couldn't communicate with anything. I ended up replacing scanner from another machine and it took right off, no issue, hell I didn't even have to program it ( sister machines, almost identical ). Everything worked flawlessly for 4 days. Now the issue is back ( not the short or bad card, just the issue once everything was repaired. ) This happened on the off shift, and the first time I know they were hot swapping ( with power still on ) cards in and out of node 2, and they probably did the same the second time.
Is there a way to erase the scanner and start over? I cant communicate with it right now. Rslink don't see it at all. If I cycle power, it will see it, until I upload or download then I lose it again. I am just using my laptop thru Ethernet. Should I buy a DeviceNet Interface Cable 1784-U2DN? Any suggestions? I have 2 new scanners coming.... Thanks
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,453
I would like to request everyone's help so i can enjoy the holiday seasons. Our PLC for our Ship Unloader (Allen Bradley) suddenly lost all...
1,681
I have an older machine controlled by AB 5/05 processor with a DeviceNet card in slot 9 that communicates with a remote I/O rack. An input card...
2,378
Hi All! I added a combination I/O module 1794 IE4 XOE2/B to the end of 1794 RIO devicenet node. In RSNetworx for Devicenet V11 (CPR9) for some...
5,165
I have built a interface cable to connect the M12 Micro Connector on the Devicenet NetMeter to the Allen Bradley MCC buss with the open style...
2,044
