DF1 unknown CMD FNC
chudchud
Jul 2008
los angeles
I'm come across a CMD=0F and FNC=AB while going through the serial data stream to a SLC5/05. The DF1 command set and AB websitt does not refer to this CMD and FNC combination., chapter 7. I cannot find this CMD and FNC combo.
Does anybody know the exact data structure for this command?
Any help would be appreciated. Thank you.
While looking at the serial data stream going into the SLC5/03 I came across a CMD = 0F and FNC = A1. I have examined the Published DF1 command...
4,840
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
Hi, I appreciate any help to make connection between AB DF1 Micrologix 1200 and WinCC Adv project (PC station - not HMI) possible. For now I can...
607
Hello everyone. I'm new on this forum and this is my firs thread. I have problem with AB 1679-L31 tags. There are tags group (tepe INT[256]) in a...
1,104
I'm trying to convert an old panelview 600 application to the 800 and I'd like to keep the current serial comms configuration instead of adding...
603
