DH+ nodes
welcome to the forum ... but I think we're going to need more detail to answer your question ...
just a guess ... the DH+ addresses range from 00 through 77 ... and they're octally addressed (no 8s and no 9s allowed) ... for a PLC-5 processor, the addresses are usually set by DIP switches on the processor ... for an SLC-5/04 processor, the addresses are set with the RSLogix500 software using the Channel Configuration feature ...
did I come close to what you wanted to know? ...
Would that be a Binary format, decimal format, hexidecimal format, or octal format?
Sounds like a classroom question.
DH+ nodes addresses are numbered in octal format.
Some software packages may translate the node address to decimal format, but fundamentally DH+ node addresses should be considered octal.
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
144
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,347
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
352
We're using a 64K memory SLC 5/04 CPU. One day the program suddenly got erased from the CPU, causing the process to activate the emergency stop...
918
hello plc professionals , i have a plc AB 1769-l24er and 13 VFD AB 525 and HMI and STRAIX 2000 unmanaged switch .. the LOGIX Designer limiting me...
1,550
