Yeah, that's correct... but the structure of this panel is:
Keys 4bites (32 keys)
DI 2bites (16DI one bit per input)
LEDs 8bites (2bits controlling colour of LED)
DO 4bites (16DO but there's 32bites and only 16 outputs)
Maybe one solution is that the outputs are designed as the LED, 'cause both are adressed as outputs...
But how to set an digital output (not LED)?
For example the adressing is from Byte0 to Byte17:
Bits from 7 to 0
Byte0 I I I I I I I I I Keys 1-8
Byte1 I I I I I I I I I Keys 9-16
Byte10 I I I I I I I I I LED 17-24
Byte11 I I I I I I I I I LED 17-24
Byte14 I I I I I I I IxI DO 1-8
Byte15 I I I I I I I IxI DO 1-8
Byte16 I I I I I I I I I DO 9-16
Byte17 I I I I I I I I I DO 9-16
Does it mean that to set up DO1 i need to set DI14.0 and DI15.0 at the same time?
