Dial Indexer with PF525
DamianInRochester
Jan 2011
Rochester NY
1,292
Anybody have any suggestions on what the optimal parameter setup is when using a PowerFlex 525 drive (with DBR) for the quick decels required on a Dial Indexer? What "Stopping Mode" seems to work best? DC Braking?
Hi Damian,
What we use is 'Ramp to stop'. Usually the deceleration of 0.3 sec works fine for our application [I find lower than that doesn't help much, 'physics']. If the index time is slow, one sensor for stopping and checking it is home is fine. I used to have separate 'Stop' and 'Home' disc triggering 2 separate sensors for stopping and confirming it stopped where I want it to be whenever the index speed is faster. The disc are attached to the indexer shaft, so one index gives out one complete rotation of the disc.
Regards
Good Evening , I never set up a Altivar 320 Frequency Drive . I must say I never seen a more complicated drive to set up , LOL How do...
2,098
Hi Everyone, I just started to work in the tire industry and I got a project about of upgrading an old and obsolete Radial Tire Building Machine...
3,942
On a number of systems we maintain, we had been using pcAnywhere on dial-up as a backup to the Internet connection software (connecting PC to PC)...
1,169
Some of the sites I service on a regular basis still use a modem. Is it possible to configure a laptop to allow linx to connect with these modems...
3,621
We have a customer that is having control system problems. They use a PLC that has been set-up for phone/fax remote access. I have a US Robotics...
1,721
