Altivar 320 drive - Setting up the Green Dial for speed adjustment
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I never set up a Altivar 320 Frequency Drive . I must say I never seen a
more complicated drive to set up , LOL
How do you setup the green dial to control the speed ? Have any of you seen an easier instructions to set up this dial for manual speed adjustments ?
Thanks so much .
beware... I have a Altivar 312, it has a very ANNOYING "feature". Anytime the drive is set to local, you need to pretty much do a full factory reset/reconfigure to get it back to remote mode.
See SE's own video....
https://www.youtube.com/watch?v=GR8KC5NS9Ws
What Goof let it pass with THAT!?
Yes this is also the case for the atv320. But i think its only if you set the control to local. Very irritating
The setting I showed is only for the speed reference
Good Evening , One more question about the Altivar 320 3 Hp . I would like to use the drive’s 24 vdc power supply to energize a 24 vdc...
1,378
Hi, I am communicating with M241 and few altivars 320, lexiums 32 via ethernet IP and I notice when I disrupt the power supply (turn off the...
2,752
Good Afternoon Guys, I am learning/using Unity Pro S. It is very new to me as most of my experience is with Automation Direct and Allen Bradley...
2,514
All, We have a site that has multiple Altivar 66's that are being controlled by an old Square D Modbus+ network. One of the VFD's has failed...
370
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
574
