Difference btw two time stamps in Crimson3.1
gzPLC
Oct 2018
Texas
39
Is it possible to calculate the time difference between two timestamps in Redlion crimson 3.1?
Thank you,
Crimson is a pretty powerful platform so I am sure it is possible but can you give us a little more info? PLC timestamps? HMI timestamps?
Simple subtraction will give you the difference but the devil is in the details.
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
772
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
708
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,447
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,650
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,142
