Difference in I/O address range and Process Image I/O
Iman
Jul 2010
Tehran
172
Hey Guys,
In S7-400 CPUs brochure,in field of address range, I don't understand why the values of I/O and Process Image I/O are different? I know the differences of I/O and Process Image I/O (direct access). Does this difference mean all the I/Os cannot be in Process Image I/Os??
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
746
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
700
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,416
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,616
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,049
