Difference in teco and encoder
pe_vivek
Oct 2004
PUNE
i want to know the difference in teco and encoder functioning. i have some servo motors in which teco is connected for motor control. some motors are with encoder. i am little confused in understanding the type of feedback coming from both the devices. please help.
Vivek,
If by teco you mean a tachometer then:
An encoder returns an angular position on the rotating device.
An encoder can also be used to calculate RPMs
A tach can only return RPMs
Rod
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
747
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
700
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,418
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,630
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,050
