Digione iap + slc-5/04
alexbeaum
Oct 2012
québec
I got some issues with my 2 digione iap in my plant. It work just fine till I go online with RSlogix500. After a few minutes I lost the link. When it does, I open my RSLinx and I notice that Rslinx can't see anymore the SLC in question. After a few seconds, The SLc appears again with no issue. A few minutes later, the same thing happen. Here's my configuration:
DIGIONE:
serial slave: port2 / DF1
serial master: none
network master: AllenBradley TCP 2222
Serail comm: 19200 bauds / 8 databit / 1 stop bit / flowcontrol off.
My version of RSlinx: Rslinx professional 2.41.00
THX
alex
yes, the latest version.. On my channel configuration, via RSLogix, the ''Source ID'' is at 8 (decimal)... I was wondering if it could get me into trouble .
Source ID
Specify the address of the sender in this field. The valid range is 0-254 (decimal).
set appart that all the config seems the same.
Like the title says, I'm having trouble. Right now, I have a SLC 5/03 in a rack and downloaded an empty program to it through the DF1 port...
1,901
Good Day. I am connecting the Digi one IAP to a compactlogix QBFC1B ( 2 db9 serial ports) to give it internet connectivity so it can be...
2,165
I have a compactlogix L31 processor and DigiOne IAP module which I am trying to set up comms with via ethernet. The processor is connected via...
1,883
I have a PLC5/80E that I want to poll a Modbus device into using a Digi1. I have setup the message as a multihop going to the IP adress of the...
1,443
Old thread: https://www.plctalk.net/qanda/showthread.php?t=114187 I have configured many other gateway before but I can't figure this out. It...
1,992
