Digital Oscilloscope recommendations
Clevername
Oct 2009
NY
36
So I've been given the task to update some of our test equipment. We currently have some old crt scopes (which I like) and it seems nearly everything is digital now. My last run in with old fluke or tektronix digital scopes was pretty crappy. They would either not trigger, take 15 minutes to set up or figure out, not responsive for looking for anything fast, etc etc etc.
Tell me ole guru's before I drop a few grand on a new scopes whats your opinions or any recommended ones?
Well, you didn't specify how many channels you need, or the speed. Details, details... :)
But we have four Rigol 1102E's here at work, and they are cheap (but not cheaply made), durable (I've dropped ours from five feet up, not even a scratch), and it *usually* triggers nicely (I'll use the single trigger for really crummy signals, but usually it's not necessary).
It's a two channel DSO rated at 100Mhz, and they go for $400.
I could get away with a dual channel but I'd "like" to get some nicer faster equipment. :D I'm sure I could come up with "some" reason for the expense!
The most important thing to look at is the sample rate, is it fast enough to get a good samlpe of the signal you are viewing. There are a lot of scopes out there but if you get one that is not up to what you need it realy will not matter how much you pay for it.
Sounds like you've got your heart set on something faster, but for the analog noise and serial communications issues I deal with, the 100MHz bandwidth of the dual channel Rigol DS1102 is sufficient.
I, too, paid about $400 USD. One decision factor was the youtube review and a collection of tutorials
youtube review
http://www.youtube.com/watch?v=kdjpbWLi7UI
5 or 6 part Training Series on the Rigol DS1052E Oscilloscope, (same scope, just 50MHz bandwidth)
part 1, introduction
http://www.youtube.com/watch?v=Q7KnDoL8cCM
We really like the Rigols here. I have my own 1102E, so I was familiar with it. Mine's been knocking around in my truck for two years and never has had a problem.
Anyways, we use it a lot for DeviceNet troubleshooting, and unless the signal is all over the place (which it sometimes is...), it has no problem triggering.
Usually it's just a matter of hooking up the leads and hitting the "Auto" button.
It's going to give you the same 8-bit resolution that nearly all digital scopes do, so depending on your needs, a digital might not be the best choice for you.
And like all DSO's you get artifacts, something that an analog scope doesn't have to deal with (much).
This book by Michael Geier has a very nice section on the pros and cons of Digital vs Analog (overall a great book!).
http://www.amazon.com/How-Diagnose-...&keywords=how+to+repair+everything+electronic
...5 or 6 part Training Series on the Rigol DS1052E Oscilloscope, (same scope, just 50MHz bandwidth)
Actually, just a few resistors and a firmware change difference from the 1102E. When I bought mine, I was torn between getting the 1052E for $200 less and hacking it, or just plunking down the extra $200 and being done with it.
I took the coward's way out... :)
I'll assume you guys purchased from:
http://www.tequipment.net/
Nope. I got mine from www.rigolna.com, and the DS1102E is currently listed for the same price of $399.
They seem to be the cheapest. I can get myself in some trouble on there.
No doubt! :)
Gonna get;
Scopes:
DS4014
DS1102
The DS4014 is a lot of scope. Way more than what I need. Keep in mind that you will probably want to explore the accessories tabs...
Pulse Gen:
DG1022
The DG1022 is a bit underpowered (IMHO), I would rather bump that up to a 2000 or a 4000 series F/AWG. It all depends on what you plan on doing, my gear is for hobby electronics, I doubt that I would ever need a F/AWG for work.
P/S:
DP1308
Nice, but I would much rather have the DP1116A since I don't ever see a need for the -25 volt channel of the 1308, and the 1308 max's out at 1 amp.
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
263
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
456
I have a PLC type PM856 from ABB with some I/O modules and I get an error from the Digital Inputs model type DI801. The unit status shows error...
270
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
293
On the laser displacement sensor now connected to my PLC, the manual says 4mA=643 and 20mA=64,877. However, I checked with a Fluke, injecting...
898
