digital swich FnC 72, smov and BIN function
sheryl86_ann
Jul 2008
laguna
142
I encountered a digital switch and zi tried to use [DSW S D1 D2 n] where S is the head device (x), d1 (head device (Y), D2 is the device number for storing the numeric value of a digital switch and n as the total # of 4 digit switch sets (4 digits/ set)(n=1 or 2)... I understand that the digital switch has 0-9 inputs which is BCD. Do i have to convert this to binary first? When i tried, [BIN K1X D1] will give me a different output equivalent? Did the shorting of the input wires here matters? the input wires for x are shorted (can be seen in the manual also 15.3 section of FNC 72.. the outputs Y also will turn on every 100ms.. I thought putting the M8029 ( execution complete flag will do.. but it still goes ON even on the next cycle.. Which part is wrong> everything in my program?
I also tried the SMOV S M1 M2 D N function.. is it necessary here? Im still not solve with the digital switch... I would appreciate if someone can send me a sample program you used before.. Thank you very much!
Sincerely,
Sheryl -Philippines
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
262
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
453
I have a PLC type PM856 from ABB with some I/O modules and I get an error from the Digital Inputs model type DI801. The unit status shows error...
270
I am monitoring two BMXDDO3202K digital outputs for their behaviour, they are each for opening and closing, and so the on time affects how far the...
293
On the laser displacement sensor now connected to my PLC, the manual says 4mA=643 and 20mA=64,877. However, I checked with a Fluke, injecting...
898
