DIN Rail mounting hole spacing
So, in addition to having a hole drilling specialist is there also a classification for people who only strip wires? How about wire duct cover cutting specialists?
There is a job,not yet listed, in this thread that I would like to apply for. We will just call him the "person that turns things" LOL
Real communication between S7300 CPU315 2DP AND OPC
I want to realize the communication S7 and pc by cable profibus or mpi
I want to know is what is fesable and the steps to that allows me to do it
Sorry for not reporting back sooner, it was a busy year.
The holes were drilled and tapped to perfection, with the specification of "whatever distance apart" being met. The DIN rail lined up perfectly with the holes.
I notice this topic brought up another somewhat related issue, and that is how to communicate an S7 to a PC, using profibus or MPI.
Can someone please suggest a couple of options?
I know that it is important to make sure you don't make the profibus network too long by adding your PC, or make the number of nodes per segment too high, or you can bring the process down. If at all possible, try to connect when the machine is not running.
med ali haloui, can you elaborate on what you are trying to achieve? Do you want to program the PLC, add a permanent station to collect data? Just show values on a screen?
Building a small panel to replace an existing panel that is a rat's nest and has mostly rusted away. Using #10 hex key button head crews to mount...
20
11,338
I'm looking for suggestions to neatly mount equipment such as cable modems and routers which don't have screw slots or DIN rail brackets, in a...
3,112
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
136
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
580
