Direct Logic 305 Question
Brent Buss
Mar 2005
Illinois
I am new to the plc group (got thrown in actually) i've got the low level ladder logic figured out(sorta) i can make the pumps turn on and off but i need to figure out how to alternate which pumps turns on (so all pumps have roughly the same hours) can anybody at least point me in the right direction? And can this even be done? I've read some of these threads and i am NOT wanting anybody to do my work for me but i got to admit i need help and any help would be appreciated.
Brent Buss
P.S. I've got 5 pumps running off of one f3-08trs-1 relay modual.
with 5 float switches.And a DL340 cpu
Drum is not available in the 340 CPU. Try incrementing a counter for each pump every hour or the needed time resolution and comparing those to see which pump needs to be run.
I have a Direct Logic 305 D3-10B card rack and all i see online is a D3-10-b-1 will i be able to interchange with the D3-10B or where can i find...
1,581
I have a loaded Model 305 sitting... I'm 100% new to PLCs. It has two RS-232 ports... can I program it through these ports or do I need a special...
2,155
what do I need to communicate with a direct logic 305 plc from a lap top?
2,376
Greetings to all, I have a situation with a DL305, Bridge CPU F3 PMUX-1. There are to LED on the cpu, one reset and one addr. It is connected...
4,940
So this is my attempt at collecting and displaying data on a Cmore panel With a DL06. Each pair in my logic is the "Time total" or the TA15 and...
481
