ELarsen
Greetings to all,
I have a situation with a DL305, Bridge CPU F3 PMUX-1. There are to LED on the cpu, one reset and one addr. It is connected to a PC with a ribbon cable. The cpu will light the reset and the addr, then it will unlight the reset and the addr will flicker. The equipment will not operate when both lights are on, but it will function normally with the addr flickering. Any suggestions as to why this change in light status occurs w/o any equipment being used. Is this a gremlin or a programming problem or what? Thanks in advance for any leads.
Ed
Ed
