Direct Mounted Flow/Temperature Switch-Trip amplifier
jose7771
Jan 2005
42
hi 2 all ,
according to our consultants specifications,direct actuated field mounted flow/temperature switch should not be used instead receiver switch /trip amplifier should be used to generate contacts .
where as for level /pressure direct diect field mounted is acceptable .
wats the logic behind this?
Logic? Many consultant's need to justify their existance (and billing).
One possible thought? If they are using pulse type flow sensors, and actual temperature sensors (RTD's, Thermocouples), then you generally do need a signal conditioner in order to yield an actual value. Simple level and pressure switches though don't need any conditioning.
Then again, do you need actual flow or temperature? In many cases, a simple thermostat can work for out of range indication, and a simple paddle switch can be used for flow determination.
Flow switches and temperature switches have been used successfully for decades. It isn't possible to give a definitive answer without knowing the details of the process and the devices, but in general the answer doesn't make sense.
If this guy is a consultant, you are paying him. I suggest you ask him this specific question. If he can't give a clear, definitive answer related to your specific application then show him the door. A general statement like "It is bad practice" without an explanation of why means he doesn't understand it himself.
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
137
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
142
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
577
So this is my attempt at collecting and displaying data on a Cmore panel With a DL06. Each pair in my logic is the "Time total" or the TA15 and...
481
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
294
