directlogic 05 relay, triac etc
lucifer752
Aug 2012
newark nj
Hello all,
I am running a 205 to control a coil (among other things) The coil is 110vac and draws an amp.
The contact time varies but it is usually about 5 seconds, a off period of anywhere from 5 sec to 2 min. and repeat.
The relays in the 05s indicate about 500K closures before they burn out. The number of cycles can add up quickly I would like to extend that time if possible.
Should I use the standard 05 AC relay module and just change it out when it goes bad?
Use a triac output ? Use transitor output to drive a dc relay?
Thanks,
TJ
Sounds like a heater application. If you are going to stay with original 110VAC control, use a Triac output on the PLC.
Is your coil a mercury relay or contactor? Mercury will have long life, but a contactor will wear out quickly. If contactor, consider replacing with SSR.
My preference with heaters is transistor output and SSR. But I wouldn't do a transistor-SSR-contactor.
It appears that your Automation Direct DL-205 relay module replacement would cost about $8.63 per relay. Because you already have it wired up (exisiting), it would cost something in labor to change the wiring. I think at that price, I would just buy a couple of spare modules. No extra wiring, no extra parts, cheap, simple, and easy-to-replace plug-in modules.
http://www.automationdirect.com/adc...ar_PLC)/AC-z-DC_I-z-O_(Relay_Outputs)/D2-08TR
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
895
Is it correct to say that the dl05 program when uploaded does not store the current value in a v memory location? I have a customer that has one...
3,101
Hello everyone, Background: We have a Directlogic 405 PLC that has an output card that has all solenoids on it. These solenoids are on plugs with...
2,901
Can someone please explain the sinking and sourcing with respect to DL405 series PLC? I have already been through the manuals. Explanations with...
2,004
I'm new to the whole Drum idea. I tried to figure it out but couldn't. I'm wanting to use a drum or sequencer to seqence a V memory depending on...
1,460
