DirectSoft 6 Error saving
RyeGuy
Sep 2019
Toronto
Hello, I have a couple of problems with the directsoft 6 software. I couldn't find a previous answer, and uninstalling and reinstall hasn't helped.
When I connect online I get an error "opening documentation database". After acknowledging it loads the program.
However, whenever I try to save to the disk it says Error copying files.
I temporarily get around this by exporting the program file so I can monitor offline. While doing this I still can't save the project to the disk, I get an error copying files and error writing program to disk dialog again.
Is there something I'm missing that is causing this?
Check that you have permissions in the directory.
I noticed that when I tried to uncheck the read only (it isnt checked, it shows a dash) and apply it, it always reverts back to the dashed read only. I've tried this on multiple directories. I tried searching the web for ways to fix this on windows 11 but I have been unsuccesful with the methods they use.
I haven't been successful with Windows 11... I'm wondering if Directsoft doesn't like windows 11 or a particular update that has occurred
I have installed DirectSoft and had it open with a blank list of CPU's to select from. When I opened an existing project it couldn't save it.
Had to go in the program properties and the Start menu shortcut properties, go to Change Settings For All Users and click Run As Admin so it was allowed to use the folders.
I have had when I only changed the program properties that clicking on the shortcut brought up a "Needs to be elevated" popup.
I am not a Automation Direct programmer. I have done a lot of RS500 I have the DS5 software and I am able to look at the program. I am reaching...
1,203
Hello all, We have an old AutomationDirect DL405 (CPU 440) PLC, and we've been using DirectSOFT 5.3. Since we are NOT upgrading this PLC for a few...
2,301
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,400
All, I have a program that I am adding the counter on Rung 83 (see attached). The reset logic is exactly the same as on rung 84, but I can't seem...
16
4,011
I'm hurting here and really need help. I have an old machine running a AutomationDirect PLC 405. I have a data collection system that is...
1,754
