DL 05 Random Number Generator
I am not sure what you mean by you only have an off delay timer. What you have is a Timer that times as long as the rung is true, you can either use compare instructions and/or the discrete status bits to make it act as you desire.
Discrete Status Bit: The discrete status bit is accessed by referencing the associated T memory location. It will be on if the current value is equal to or greater than the preset value. For example the discrete status bit for timer 2 would be T2.
A simple example is use T2 -|/|- in conjuction with the same condition that starts the timer to turn something ON and run until the timer preset has been reached.
Or use T2 -| |- to delay on until the preset has been reached.
Have to use your imagination and think about it.
Dirtysouthdesign ,
I wanted to wait for Bernie's reply to your "works to good" comment.
Dirtysouthdesign said:
Honestly i am not a programmer;
Any help i will greatly thankful for....im an M.E. wish i was a programmer !!!
My solenoid is on a 20ms offdtmr and i need it like that so the mag field builds has time to build up and give a good pop !
Not knowing what type of outputs you have and making a presumption that you have 24V DC outputs. I just wanted to make sure you knew about the problem with inductive loads and PLC outputs. A solenoid is an inductive load. You might be lucky in that one of the output protection schemes makes the output magnetized longer. This protection scheme is the "reverse bias" diode that conducts the voltage spike that the coil makes when the voltage is turned off. The effect is the coil regenerates it's own power keeping it magnetized longer. For most of us in the controls industry this is a problem we live with. But in your case this might be a asset. The plus side is that you also protect your outputs.
Hey folks, I was just wondering what thoughts were about a completely 100% random number generator. I looked on The Google but didn't really open...
54
16,550
Hello, Could somebody please help me out with coding a 'Random number generator' in vijeo citect. For example if i create an analog Local...
3,770
Hi,Does anybody know if there are any routines in unity pro that produce random numbers like the routine rand() in C ?
4,034
Ive got a client that needs random numbers generated for a security system. Just want to know if any 1 has some ladder or ST software or scripts...
8,895
Hi guys, I need your valuable suggestions about writing a module (AWL Step7) generating random integer numbers... Let's say the users define the...
19
20,666
