OT: Random Number Generator
OT (snort)
OT OT OT
Two out of 10k looks about right, but I'll have to think about why my two-the-same validation is off by a percent or so.
$ more 4.py
from random import randint as ri
counts = [0]*100
last10 = [ri(0,99) for i in range(10)]
for i in last10: counts = 1
inext,total2,total4,totaltest,samples = 0,0.0,0.0,0.0,list()
twos,fours = set(),set()
try:
while True:
irand = ri(0,99)
ilast = last10[inext]
if 2 == counts[ilast]: twos.remove(ilast)
counts[ilast] -= 1
if 3 == counts[ilast]: fours.remove(ilast)
counts[irand] += 1
if 2 == counts[irand]: twos.add(irand)
elif 4 == counts[irand]: fours.add(irand)
totaltest += 1
if len(twos):
total2 += 1
if len(fours):
total4 += 1
tup = (total2,total4 ,totaltest
,total2/totaltest,total4/totaltest,)
if len(fours) and (0.0 == (total4 % 50)):
print(tup)
samples.append(tup)
last10[inext] = irand
inext += (inext < 9) and 1 or -8
except KeyboardInterrupt: pass
p2 = 100.**(-9)
for i in range(91,100): p2 *= float(i)
import matplotlib.pyplot as plt
total2s,total4s,totaltests,total2prob,total4prob = zip(*samples)
fix,(ax2,ax4,) = plt.subplots(1,2, sharex=True)
ax2.plot(totaltests,total2prob)
ax2.axhline(1.-p2)
ax4.plot(totaltests,total4prob)
plt.show()
At least 4 or just 4. There is a difference.
I just want to make sure before I get into the probabilities. I am assuming drbitboy's answer 4 the same out of 100 is correct but I would like to prove it.
Letting my geek flag fly!
To use the approach where backing up to the solution gives the correct answer, I am certain it is "at least four," which is the point I made in your first post with the Birthday-Problem-ish query, and which is also the approach my Python code uses i.e. "at least four" and "at least two."
"Exactly two" or "exactly four," OTOH, gets messy, because you have to consider how you are going to handle multiple instances of duplicate values e.g. [99,98,98,97,97,97,96,96,96] does have both exactly two 98s and exactly two 96s.
For example, say the task was to pick four numbers with replacement from a set of 10; there would be 10k (10**4) possible combinations:
  • 5040 "1 the same" i.e. all unique
    • 5040 = 10 * 9 * 8 * 7, i.e.
      • All 10 possible for the 1st pick,
        • which leaves the 9 values not picked 1st as possible for the 2nd pick,
          • which leaves the 8 values picked neither 1st or 2nd for the 3rd pick,
            • which leaves the 7 values picked neither 1st nor 2nd nor 3rd for the 4th pick
  • 4320 "exactly 2 the same, the others different from each other"
    • 2160 = 10 * 9 * 8 * 3
      • 10*9*8 => First three picks are unique,
      • 3 => 4th pick same as one of the first 3
    • 1440 = 10 * 9 * 2 * 8
      • 10*9 => First two picks are unique
      • 2 => 2nd pick sam as one fo the first 2
      • 8 => 4th pick unique
    • 720 = 10 * 1 * 9 * 8
      • 10*1 => First two picks are the same number
      • 9*8 => 3rd and 4th pick are different both from the first two picks and from each other
  • 360 "Exactly 3 the same"
    • 180 = 10 * 9 * 2 * 1
      • 10*9 => First two pick are unique
      • 2 => 3rd pick has to match one of the first two
      • 1 => 4th pick has to match 2rd pic
    • 90 = 10 * 1 * 9 * 1
      • 10 => 1st pick is unique
      • 1 => 2nd pick matches 1st pick
      • 9 => 3rd pick is unique from first two picks
      • 1 => 4th pick has to match first two picks
    • 90 = 10 * 1 * 1 * 9
      • 1 => 3rd pick matches first two picks
      • 9 => 4th pick is unique from first three picks
  • 10 "Exactly four the same"
    • 10 = 10 * 1 * 1 * 1
      • 1*1*1 => last three picks match the 1st pick
  • The total so far is 9730, or 270 short of 10k, because we did not consider:
  • 270 "two the same, and the other two both the same and unique from the first two"
      • 10*9 => First two are unique
      • 2 => 3rd pick matches one of the first two
      • 1 => 4th pick matches the other of the first two
      • 1 => 2nd pick matches first pick
      • 1 => 4th pick matches third pick
Note that there are four groups, indicated by the bold underlined colors above, each group with the same first three numbers, and the four numbers in each group sum to 10:: 10*9*8*[7,3], 10*9*2*[8,1,1], 10*1*9*[8,1,1], 10*1*1*[9,1].
"Exactly two" or "exactly four," OTOH, gets messy, because you have to consider how you are going to handle multiple instances of duplicate values e.g. [99,98,98,97,97,97,96,96,96] does have both exactly two 98s and exactly four 96s.
Correction in bold above.
$ cat 10.py
import sys
L = [(int(([10]+sys.argv[1:]).pop()),)]
s=set(L)
while L:
t = L.pop()
for i in range(len(t)):
pfx,ival,sfx = t[:i],t,t[i+1:]
j = len(pfx) and pfx[-1] or 1
while (j+j) <= ival:
k = j
j += 1
newt = t[:i] + (k,ival-k,) + t[i+1:]
if newt in s: continue
L.append(newt)
s.add(newt)
import pprint
pprint.pprint(sorted(s))
print(len(s))
Might come in handy. Jes' sayin'
It did; the script is attached.
> python 10.py
Sampling 10 items at a time out of 100:
- At least 1 the same: probability= 100%; count=100000000000000000000=1e+20
- At least 2 the same: probability= 37.1843%; count=37184349044470528000=3.71843e+19
- At least 3 the same: probability= 1.13653%; count=1136534315040640000=1.13653e+18
- At least 4 the same: probability= 0.0200126%; count=20012610593260000=2.00126e+16
- At least 5 the same: probability= 0.000241678%; count=241678430740000=2.41678e+14
- At least 6 the same: probability= 2.02894e-06%; count=2028939412600=2.02894e+12
- At least 7 the same: probability= 1.16878e-08%; count=11687791600=1.16878e+10
- At least 8 the same: probability= 4.42036e-11%; count=44203600=4.42036e+07
- At least 9 the same: probability= 9.91e-14%; count=99100=99100
- At least 10 the same: probability= 1e-16%; count=100=100
> python 10.py 5 10
Sampling 5 items at a time out of 10:
- At least 1 the same: probability= 100%; count=100000=100000
- At least 2 the same: probability= 69.76%; count=69760=69760
- At least 3 the same: probability= 8.56%; count=8560=8560
- At least 4 the same: probability= 0.46%; count=460=460
- At least 5 the same: probability= 0.01%; count=10=10
Schrödinger's cat disagrees with you ;-)
That darn cat! It always gets into trouble.
The key being 'all *data* was known and calculated.' If the uncertainty principle is true, it is simply impossible for this to be the case -- limits to our ability to measure (and thus know or calculate) are a fundamental property.
Heisenberg tells us that even if you know the starting conditions, there are limits to how accurately current values can be known.
Ofcourse its not very practical, neither is the above cat :)
It is hard to tell what you are trying to do because you keep changing the problem.
Can we go back to picking the same 4 numbers out of 10 with replacement? Assume even probability for each digit or p=0.1 This problem can be easily brute forced and compared with a formula.
Basically there are 10*digits*10 numbers so there are 10^10 combination of numbers from 0-9. This can be brute forced by generating all the numbers and counting how many have 4 digits of the same value.
More good stuff
https://www.statology.org/binomial-distribution-python/
No, I am not. I have been doing the birthday problem using the "At least N matches" semantic, where N can be an integer other than 2.
I already solved the four out of 10 by hand.
That is incoherent. Do you mean "Pick four (N=4) digits out of ten (M=10) with replacement, and determine what is probability of at least 2, or at least 3, or at least 4, the same? Obviously the last case is always * M**(1-N).
The number of items sampled makes a difference but if sampling with replacement then it makes no difference if there are 100 items or 1000 items. Only the probability of the picking an item matters.
You are solving a little bit different problem with your "at least" qualifier.
Code:
from scipy.stats import binom
#calculate binomial probability of selecting k items the same
k=0     # the number of items that ARE THE SAME
n=10    # the number of items in a sample
p=0.1   # the probability of selecting an item
sum=0.
for k in range(0,n+1):
    prob = binom.pmf(k,n,p)
    sum = sum + prob
    print(f"probability of {k} items being the same {prob} and the sum is {sum}")
The output is
Code:
probability of 0 items being the same 0.3486784401000001 and the sum is 0.3486784401000001
probability of 1 items being the same 0.38742048899999965 and the sum is 0.7360989290999997
probability of 2 items being the same 0.19371024450000007 and the sum is 0.9298091735999998
probability of 3 items being the same 0.05739562799999998 and the sum is 0.9872048015999998
probability of 4 items being the same 0.01116026100000001 and the sum is 0.9983650625999998
probability of 5 items being the same 0.0014880347999999995 and the sum is 0.9998530973999998
probability of 6 items being the same 0.00013778100000000007 and the sum is 0.9999908783999998
probability of 7 items being the same 8.748000000000003e-06 and the sum is 0.9999996263999997
probability of 8 items being the same 3.6449999999999996e-07 and the sum is 0.9999999908999997
probability of 9 items being the same 8.999999999999995e-09 and the sum is 0.9999999998999997
probability of 10 items being the same 1.0000000000000006e-10 and the sum is 0.9999999999999997
python also has a cumulative density function, cdf
Code:
probability of 0 items or less is 0.34867844009999993
probability of 1 items or less is 0.7360989291
probability of 2 items or less is 0.9298091736
probability of 3 items or less is 0.9872048016
probability of 4 items or less is 0.9983650626
probability of 5 items or less is 0.9998530974
probability of 6 items or less is 0.9999908784
probability of 7 items or less is 0.9999996264
probability of 8 items or less is 0.9999999909
probability of 9 items or less is 0.9999999999
probability of 10 items or less is 1.0
[code]
the output is
[code]
These numbers should match the sum numbers above.
drbitboys at least k is 1-binom.cdf(k-1,n,0.1)
It better be. I will let someone else check that out.
for those that like to play table tennis or those that want to dig deeper into python's binom or Mathcad dbinom functions then look at this. This is the only TT handicap table on the internet where the probabilities and handicaps were calculated.
Code:
probability of 0 items being the same 0.3486784401000001 and the sum is 0.3486784401000001[code][/QUOTE]
As my son used to say, when he had his Volvo 5-speed Turbo S70, and someone would pull up next to him to use the merging right lane on the other side of the the light to get ahead: "I don't think so."
[LIST]
[*]The least 10-digit decimal number is 0000000000
[*]The greatest 10-digit decimal number is 999999999
[*]There are 1E10 (= 10 to the 10th power = 10**10 = 10^10) possible elements in the set of all 10-digit decimal numbers
[*]I think we can agree that the 10 digits in each element of that set of numbers is equivalent to exactly one possible sample of 10 items with replacement from a reservoir of items of 10 types
[*]The least 10-digit decimal number with "0 [digits] being the same" is 0123456789 (N.B. that includes the leading zero);
[*]The largest such decimal number is 98765432310;
[*]the count of all such "0 digits the same" decimal numbers is 3628800 (= 10! = 3.6288E6).
[*]So if we sample 10 items with replacement from a reservoir of items of 10 types, the probability of the sample having 10 uniqe items (0 the same) is (3.6E6 ÷ 1E10) = 3.6E-4, or almost three orders of magnitude less than @Peter Nachtwey's 0.3486784401.
[/LIST]
That's a quick off-the-cuff check, and I will not be surprised if it is wrong in some way.  So consider also the following tests:
1) Empirical check that Python [B]random [/B]module's .[B]randint[/B](lo,hi) method (cf. [URL="https://docs.python.org/3/library/random.html#random.randint"]this link[/URL]) is uniform:[INDENT][ladder]
### Initialize a dictionary (hash table) with keys 0 through 9
>>> d=dict([(i,0) for i in range(10)])
>>> d
{0: 0, 1: 0, 2: 0, 3: 0, 4: 0, 5: 0, 6: 0, 7: 0, 8: 0, 9: 0}
### Take ten million samples of the digits 0 through 9 using random.randint
>>> for i in range(10000000): d[random.randint(0,9)]+=1
### Print the histogram of those samples
>>> d
{0: 1001439, 1: 1000790, 2: 1001262, 3: 1000092, 4: 999470, 5: 1000007, 6: 999654, 7: 997713, 8: 999378, 9: 1000195}
[/ladder]
[/INDENT]1.1) Is a distribution of random.randint samples uniform?  Yes, apparently so.
2) Is the probability of getting 0 digits the greater than the one in three, which @Peter Nachtwey predicts, when sampling 10 decimal digits at a time with replacement?[INDENT][ladder]
>>> for i in range(10): print([random.randint(0,9) for i in range(10)])
[[COLOR=Blue][B]2[/B][/COLOR], 3, 9, [COLOR=blue][B]2[/B][/COLOR], 1, 4, 1, 5, 1, 9]
[[COLOR=blue][B]0[/B][/COLOR], 8, 6, 9, [COLOR=blue][B]0[/B][/COLOR], 3, 8, 4, 6, 0]
[5, [COLOR=Blue][B]6[/B][/COLOR], 1, [COLOR=blue][B]6[/B][/COLOR], 3, 9, 3, 1, 8, 3]
[[COLOR=blue][B]3[/B][/COLOR], 6, 7, 7, 6, 5, 0, [COLOR=blue][B]3[/B][/COLOR], 7, 9]
[[COLOR=blue][B]8[/B][/COLOR], 9, 5, 5, 6, 4, 7, 9, [COLOR=blue][B]8[/B][/COLOR], 4]
[7, 2, [COLOR=blue][B]0[/B][/COLOR], 9, 6, 8, 1, 4, [COLOR=blue][B]0[/B][/COLOR], 8]
[[COLOR=blue][B]6[/B][/COLOR], 3, 3, 3, 5, [COLOR=blue][B]6[/B][/COLOR], 3, 7, 4, 4]
[0, [COLOR=blue][B]7[/B][/COLOR], 3, 8, 4, 6, 9, [COLOR=blue][B]7[/B][/COLOR], 4, 6]
[7, [COLOR=blue][B]6[/B][/COLOR], [COLOR=blue][B]6[/B][/COLOR], 4, 2, 4, 2, 9, 2, 9]
[[COLOR=blue][B]2[/B][/COLOR], 0, [COLOR=blue][B]2[/B][/COLOR], 1, 1, 1, 9, 5, 1, 9]
[/ladder]
[/INDENT]2.1) No, it is much less than 1 in 3.
Probability, like measurement, is hard
Hello, Could somebody please help me out with coding a 'Random number generator' in vijeo citect. For example if i create an analog Local...
3,770
Hi,Does anybody know if there are any routines in unity pro that produce random numbers like the routine rand() in C ?
4,034
Ive got a client that needs random numbers generated for a security system. Just want to know if any 1 has some ladder or ST software or scripts...
8,893
Can anyone help me create a few ladder logic lines to randomly generate intergers btw 0-100. I have tryed loading the scan timer value, then ANDD...
13,342
Hi guys, I need your valuable suggestions about writing a module (AWL Step7) generating random integer numbers... Let's say the users define the...
19
20,663
