Random number generator in Vijeo Citect SCADA
Mishtavince
Jan 2014
Gulf
19
Hello,
Could somebody please help me out with coding a 'Random number generator' in vijeo citect.
For example if i create an analog Local variable, i would want that variable number to change every 2to3 secs with numbers between 0 to 240.
I tried using the Rand() function, all i got it to do is change from 0 to 1. I am a bit weak and new to citect as I've been working with it for barely a month.
I would really appreciate any input or an example code on this.
Thank You.:)
Thank you Nhatsen,
Is there a way to update it every few seconds?
variable = Rand(241);
the above only give a '0' in run mode
Hey folks, I was just wondering what thoughts were about a completely 100% random number generator. I looked on The Google but didn't really open...
54
16,545
Hi,Does anybody know if there are any routines in unity pro that produce random numbers like the routine rand() in C ?
4,033
Ive got a client that needs random numbers generated for a security system. Just want to know if any 1 has some ladder or ST software or scripts...
8,882
Can anyone help me create a few ladder logic lines to randomly generate intergers btw 0-100. I have tryed loading the scan timer value, then ANDD...
13,341
Hi guys, I need your valuable suggestions about writing a module (AWL Step7) generating random integer numbers... Let's say the users define the...
19
20,651
