DL-PLC adding lines of code
Clay B.
Jun 2005
Concord,NC
1,304
I have a bit of a puzzle. It is not causing any faults but I would like to know the cause. What I have is a program with mulitiple sub routines. In the last subroutine the PLC keeps adding ruings for some reason before the return rungs. The rungs look like what this:
K0
___________________________________(???)
Anybody know what causes this. The program is in a plc I built as a simulator (DL6 D0-06DD2-D) and as far as I can tell this is not causing any issues yet. If you need to see the actual code let me know.
Clay
edit: the K0 is supped to be over the output
I think I would need to see the code in order to possibly explain it. Offhand I really can't come up with a good reason for this happening.
A .zip file of the program would be great.
Ps. The program will be 6-20 siles all with the same name and different extensions.
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
150
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,128
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
677
Dears I use step7 v5.4 with Winncc v6.0 cpu 414-2DP i need to adding production running time as accumulating during day and night shift and...
1,782
Good afternoon all, I have an AB SLC 5/03 which uses multiple AC i/o cards (such as 1746-IA16 and 1746-OA16). I am using a 7-slot chassis with...
1,363
