DL06 Data logging
Johnny_Rotten
Sep 2019
Belleville
Just been working for a few years as a normal Electrician. Hey Phil. So working on a simple process just going 16 bit, a couple analog sensors in, and relays to start systems, and possibly an analog out, or two. Going to use the typical c-more micro hmi. I want to use a dl06 just because I do know how to program those guys, but oddly never had done data logging. I have heard I can either use a network card, and scada software on a remote computer, or have the hmi do the data logging itself.
Nice to be back.
The DL06 has a serial port capable of Modbus RTU. You could use a program like AdvancedHMI to communicate and log the information.
https://accautomation.ca/advancedhmi-to-solo-process-temperature-controller/
The above link is a simple program to get information from the Solo temperature controller using AdvancedHMI through Modbus RTU.
The other option is to use a Do-More or Productivity 1000 series plc and log the data to a micro SD card. This would put a file on the card that can then be emailed out on a regular basis.
https://accautomation.ca/brx-plc-data-logging/
https://accautomation.ca/productivity-1000-series-plc-data-logger/
Here are the complete series on each of the controllers:
https://accautomation.ca/series/brx-do-more-plc/
https://accautomation.ca/series/productivity-1000-plc/
Another way is to use a C-More instead of the C-More Micro. The CMore has data logging capability (CSV) as well as a FTP Server to retrieve the information on a network.
I hope this helps you out.
Regards,
Good morning and Happy New Year to everyone! I have been recently working on a project involving a PLC in which i have no experience with...
3,758
Hello all, First off, I would like to thank all of you who helped me get up and running with some math functions in my project using the DL06...
19
9,437
Hi Every Body... Years ago, i made a PLC(dl06) control based oven, but the problem came on data logging, couse i use data worx but in some...
2,463
I need some help. I am new to S7 but have a pretty good grasp on it. What i am wanting help with is addressing DB data and sending it to an...
2,153
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
502
