DL06 EDRUM to MDRMD
amm
Mar 2007
Northern Illinois
17
Hello I was hoping I could get some guidance, on how to best modify a program I have running a lifecycle test station, with 3 electronic locks being tested at the same time.
My current program has an error check which is using the Event part of the EDRUM to look for a failure of an electronic lock to stay locked.
It currently uses 3 consecutive EDRUMs one for each section of the lifecycle test. I was hoping to use 3 MDRMD instead but they aren't the easiest things to set up. At least that is what I have learned so far.
The project files are linked to below.
https://drive.google.com/drive/folders/0B_7OqHpsv7NDc01udVVEVWFCZFE?usp=sharing
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
510
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
940
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,168
I have a client that has many Automation Direct DL06 PLCs for a municipal water/wastewater system. When there is a power outage, one of the sites...
2,458
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,370
