Do-More Calculate Velocity from Distance Sensor HELP
brandoncosta
Feb 2011
SLC
37
I'm using a Do-More and a Leuze Electronic ODSL 9 sensor to monitor a large hydraulic cylinder. I have to calculate and log the velocity. I have tried to capture a reading based on a 50ms or 100 ms clock the move that to a R location then capture a second and move to another R location then do the math between the two and do the calculation. I cant get it to work. Does anyone have a suggestion on how to get there. The fastest the cylinder could be moving is 17'/sec. The stroke is 5'.
Hello, i need to use P_Intlk and feed the Status interlock OK bit to a P_DOut block. However, there's 17 interlocks for this output. How can I...
128
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
120
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
287
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
202
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
523
