ceilingwalker
Hello all. I did a search here for Do-More (Automation Direct Software) and didn't see many questions. Thanks to Covid-19 I was unemployed for a couple of months, now I am back to work at a new employer that swears by Automation Direct for all their automation h-ware and s-ware. Never used this platform before. Thankfully, it's pretty easy to use so, moving right along.
I have a project that has an ibox that is logging data, all is well. I am trying to email that project using an ibox EMAIL, with an SMTP device. I have it set up and it is sending the message to my email however, only the message itself, not the attached data log file. On the EMAIL ibox it shows "On Success, Set bit" (C2) and "On Error, Set bit" (C3).C2 is always false and C3 is always true. My project was created as a simulator project which, from what I understand, IS a fully functioning PLC. The fact that it is sending the email successfully tells me it is set up correctly and it does show an attachment however, I am unable to open this attachment. I was hoping someone here has "been there, done that"? Thank you
