Downloading PDF's from Siemens comfort panels
Marshy
Apr 2007
Bath,UK
236
For some reason when I try and download a pdf file from the 'file browser' in the Simatic HMI Miniweb, Chrome and Internet Explorer change the extension to htm, does anyone know why this may be happening? I do not get this issue when downloading pdf from other Internet sites.
The HMI is a TP700 Comfort.
Any help / ideas would be appreciated.
King Regards
Rich
Is the computer downloading just the .PDF or is it downloading the entire webpage (.HTM) that includes the PDF?
It may be something similar to IE's famous "Print All" default when you select something on a webpage and want to print only that selection. IE may be downloading the entire page. If it does this there should be a file called [webpage].htm and a folder called [webpage] that holds all objects from that page, with the PDF being one of them, move the PDF somewhere else & delete the webpage files
Thanks for the reply. No it's just downloading the file, if I change the htm extension back to pdf it will open as it should.
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
302
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
587
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,193
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,100
Hi all, I've run into an error I haven't seen before while attempting to download the “Programming” tab of RMCTools to an RMC200 Lite I just got...
3,668
