Downloading Recipes to PLC5
Will8
Jun 2007
Van
Hi all, would greatly appreciate some input/advice on how to download recipe files to ControlNet PLC5. It is my first time working with ControlNet and PLC5/40C15. The setup is like this.
I'm running two L64 controllers with a 1756-CNB in the same rack. Hooked up to the CNB is a ControlNet PLC5/40C15. I'm able to see everybody on the network. I'm using RSLogix5 and RSView Machine Edition. The L64s are programmed via RSLogix 5000. I have a program that contains recipes for the two L64s and the PLC5 via direct reference tags. I'm able to download and restore recipes to the L64s but not to the PLC5.
What is the proper way to setup such a network? I assume something needs to be done on the RSNetWorx side to setup the ControlNet properly as well.
Any input is greatly appreciated. Thanks!
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
302
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
587
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,193
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,100
Hi all, I've run into an error I haven't seen before while attempting to download the “Programming” tab of RMCTools to an RMC200 Lite I just got...
3,668
