Downloading site to Moscad ACE3600
ssnickson
May 2011
singapore
I m currently working on ACE3600 as i m new to this system. I need your help to guide me how to download a simple site configuration into RTU
I have done harware test and manage to read RTU through my PC connected to the RTU serial port. So i assume that my connection is corrent
I have use 1 serial link of RTU to connect my PC and 1 Plug in port to connect Radio (GM338) to RTU
I want to download this config into RTU but when i try to download it give me a error
"There is a conflict between STS expected firmware v13.00 and RTU actual firmware v15.00
Consider downloading the firmware to the RTU
Current firmware version : 15.00-R-015
Unit type : ACE 3600 CPU 3640
Configuration version: 14.50 isn't higher than the RTU firmware version: 15.00.
Download operation won't be performed!
Failed to convert configuration file to DNL
ERROR: Error calculating buffer size of Site Configuration file 'C:\STS1450\Projects\P11-0029\634402~1\files\conf.cfi'
Download failed. Error code: 8065000C"
Anybody can help me how to solve this issue.
Hi all, I am trying to download RSL 5000 V21 from the RA website. I have a tech connect contract. I put in my company name and S/N and it takes...
4,485
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
302
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
590
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,194
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,101
