Downloading to Panelview and retaining connection
rocksalt
Aug 2008
Texas
102
I am accessing PLC's from my office on a VLAN. I have a dedicated ENBT for intranet connections. I want to be able to create a .mer file (when I run factorytalk in the office I have to change the communications path to check my work) from the office and send it to the machine without walking to the machine to configure the communications path.
Would I need to manually enter the path and then download it or could I deselect the "replace communications" in the transfer utility?
"Replace Communications" is a bad idea.
When testing screens within FTVS (office PC) you are using the path listed within the RSLinx Enterprise/Communication Settings Design(Local) Tab.
When testing the Runtime on yor FTVS running PC ("Running Man" button) or when the .mer is deployed into a field installed PV+ terminal the Runtime application is using the path listed in RSLinx Enterprise/Communication Settings Runtime(Target) Tab.
If the two paths are identical then the developer used the dreaded "Copy from design to Runtime" "feature".
Edit the Design path and add all the devices between the PC and controller from the PC's "perspective".; leave the Runtime path alone.
I have a SLC 5/03 and I connect vie 1747 UIC cable via ethernet plug in. The panelview 600 PN is - 2711-T6C16L1 It is only TOUCH screen. I had...
2,605
Good Afternoon , I have a Panelview Plus 7 Performance HMI. I made some screen changes and created another runtime. I downloaded to the...
2,483
Hi, It's my first time trying to use panel view, although I've touched briefly on RSLogix. I'm struggling to connect to the panel view. When I...
2,302
I'm currently updating an existing PanelView 1000. I am using PanelBuilder 32 (V3.82) to make the modifications to the client supplied backup of...
5,116
I want top download a Panelview app into a Panelview 550. My laptop uses XP service pack 3. I can not step back to Service pack 2. Am using...
2,504
