DSE Lite software
IO believe the difference is that an install will only install parameters related to "drive application". This would include things line motor nameplate data, max and min speeds, accel/decel rate, function block linking, etc. A full install would download all the parameters from a standard install but would also install what are called "frame dependent" parameters such as drive drive max current and drive voltage rating.
I have only done a full install a couple of times and then only when told to do so by SSD. I'm pretty sure you can get a drive control section pretty unhappy if the frame dependent parameters don't match the actual drive power section.
Keith
A couple of years ago i got a tip from a drive engineer specialized on Parker (SSD drives).
He said that the best thing to do is first do a full upload from the drive to your computer, then make the changes you want and programming and then do a full install.
Keith
Thanks for reply.It's very helpful. Do you have document about this problem ?
Thanks for reply. I will use this way.(y)
Hi Friends, I want to Integrate data from a DSE 8610 Power sharing Module onto a PC via Modbus. Which amongst the two methods below is better...
2,051
Can anyone help me invert the correction to the speed demand in the section control block. The drive's base speed is correct, however the...
2,278
Hi all! Can anyone assist me with some notes or tutorials on the DSE 8005 Scada Suite PC Software from DEEP SEA ELECTRONICS PLC? I received the...
3,634
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
687
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,696
