DTAM error
roxusa
Nov 2008
NJ
994
What is the difference between 1747-DTAM-E & 1747-DTAM
Mine does not have an E on it, When I connect it it does the power up and
goes through diagnostic then gives error 100. I downloaded the AB Manual but it says for DTAM-E is this the correct manual for a 1747-DTAM series A
& do I need to configure my module. According to the 1747 d=DTAM-E manual I have a "ROM memory failed checksum test" and says to reset module. I have never set up one of these units before but have used them when they were already on machine. Cleaning out shop I found this one and wanted to test if it was good. Thanks
I think they are two different user manuals, The E and micro possibly use software and the plane 1747-dtam does not, im still looking for the 1747-dtam user manual have you had any luck locating one?
Never found one, Dtam still on my bench with a dozen other jobs, I'll look again. Thanks
Then I guess this one is bad since the manual says reset unit which is power off and on and I continue to get the same error. Thanks
I have upgraded my SLC 500 from a 5/01 CPU to a 5/03 CPU with and without changing data tables and I/O. However, my 1747-DTAM external module now...
4,042
Hello, I have a machine that had an SLC 5/02 with Link Coupler, DTAM, etc. and the processor and power supply failed, losing the program. Tried...
1,121
Our SLC500 5/02 had a CPU fault for an unknown reason. The program was gone so I had to re-download the program. And it's running now. But...
3,333
hello i hope you are having great day :o: so my problem is, i have a 1747 DTAM-E conected to a DH485 interface it was working fine.. after...
2,199
Need Help I am looking for software for Allen Bradley Dtam Plus . I think it is 2707 NP. thanks
2,980
