Dual Air-Compressor Lead/Lag
Aug 2006
Virginia
I'm new to plc programming but I was wondering if anyone has a sample program for a dual air compressor lead lag circuit for a SLC500. This would be activated by Wonderware and only one compressor would run at a time. If #1 Compressor is running and the pressure falls below 60psi, then #1 would cut off and #2 would come on. Also there needs to be a 5000 Hour Timer to Flip-flop the compressors and alarm for maintenance.
I do not have an example but I could probably make a basic program. Provide more details, like an I/O list, and I will give it a shot. What size are the compressors? i.e. are they DOL, Wye-Delta, softstart, or VFD started? Do the compressors control their unload or will that need to be controlled? What alarms? Will the plc monitor more then line pressure?
86
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
93
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,144
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
444
I am passing DINTs between a Micro800 and CompactLogix - each bit in the DINT has its own unique meaning. On the Studio5000 side I can just write...
1,107
