Dual Coil Relay?
I_Automation
Jun 2020
Detroit, Michigan USA
1,648
I thought of this before and always did like everyone else and put 2 relays next to each other and wire the contacts parallel, but...
Has anyone ever seen a relay with 2 separate coils that either/or coil or both coils will close the same sets of contacts?
Mechanical relays, not solid state or transistor output.
I know for DC I could wire 2 signals through diodes, but still wondering if this exists.
I have seen it more than a few times
It was a magneticly latched set up
It's a set reset relay pulse one coil in to set it and the other to reset it
I have not seen them for a number of years now since plc's have taken over
P&B has them if I remember they were available in 24vdc and 120 vac
It wouldn't take much to put one together with 2 relays interconnected
86
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
93
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,144
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
444
I am passing DINTs between a Micro800 and CompactLogix - each bit in the DINT has its own unique meaning. On the Studio5000 side I can just write...
1,107
