E-Terminals E50 display...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
Just got a new machine in with an E50 display. I decided to suck the project out of it for backup purposes. I've previously only used the E100 and up terminals, so I'm confused as to why the 'Receive' button in E-Designer is grayed out. Can't the project be uploaded from the E50 terminals?... :unsure:
-Eric
Thanks for the confirmation, Goody. I didn't see that specifically mentioned in the manual.
The E50 are quite limited, so it wasn't much work to recreate the project from scratch.
Only 10 blocks and 20 variables, but it would have been nicer to just upload it... :rolleyes:
-Eric
Ah! yes very limited the E- 50 terminal However I never tried it, but if you hold the (f3) and (f4) keys simultanusly as you power up puts the terminal in manual transfer mode.
I do perfer the e-150 and up . we use the e-50 in our simple version of sleeving machine.
Thats basically what I meant, The holding of the buttons at boot up to put it into transfer mode.
Plus the fact that I have several versions of E designer and the older MAC Programmer+ and the recieve button is greyed (not grAyed in UK :)) in all of them.
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
436
6FX5002-2CD24-1GR0 Via Siemens Sinamics SINAMICS S120 are cuted. I got 1 project that they relocating old Machine to install to new location. Mut...
61
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
204
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
221
With Wonderware, IFIX, FactoryTalk View, etc., it's very easy to have multiple HMIs, each with their own independent control, looking at the same...
535
