E1070 communication issues
kevbloke
Jul 2004
Kent uk
81
Hi Guys,
I am trying to verify a project in a Mitsi E1070 HMI. I cant get it to communicate at all. I have tried software versions 6.13 and 7.52 but no joy. I have been through all of the baud rates and am using the correct com port. I am using the correct lead (CAB30) and have hit a wall!
Any ideas please?
The HMI has an inbuilt ethernet port, it gives the IP address at boot up, set your PC to use the same subnet and connect via a crossover ethernet cable rather than serial. In the transfer menu set communications to use ethernet. If the ethernet port is already in use then so much the easier, you just need to connect to the machine LAN with a standard ethernet cable.
edit: If you do want to stick with serial you do know that the newer E1000 range uses a different serial cable from the older HMIs?
Bryan
Hi peeps, Quick question for u Mitsi Beijer guys We have a project at work which (possibly) involves adding another E1070 HMI but with full...
1,663
I am asking on here in case anyone has come across this before. I have also asked it on mrplc.com to try reach a wider audience as I am a little...
2,222
Using the E1070 with a FX3U Mitsubishi PLC in a machine tool application. We've used this HMI for several years with no problems. Now this...
3,260
Does anyone know what this code means? FS_WRTR DATA ERR #4 This error occurred at a new customer installation after three days of running the...
2,363
Dear Folks, I'm trying to use a E1070 HMI in connection with a Keyence LK-G Laser ( LINK ). The Laser is connected with the HMI by RS232...
22
5,871
