e50 hmi
jjjaayyy
Sep 2005
croxton
can some please help please
building a new control panel but have problems
always use mitsi plc's and now on the q series
started commisioning the panel carnt get my q series mitsi to talk to my e50 hmi alway used this in the past for alarm screen for panel satus with the the a series anyone help.
ps just battled my way through the ad and da cards they are all sorted.
do you think i will have to change the hmi for a biggger one
many thanks mr desperate
The E50 was built long before the Q series plc's came out and as such, there is not even an option for a connection to this model.
I think you might have to go up a few models
when i purchased the hardware the speced the lead from the q to hmi.
i have tried to update my e-design software. but there is no upgrade i can see. i think the company who sold it to me need to sort it out. i have a new e300 in stock i think the only way is to fit this (bugger only qouted for e50 on the job) many thanks mr desperate
thanks silva foxx i did read that earlier on my vain search for the answer. i think i was just clutching at staws. Least the cut out size in the panel door for the new screen will be bigger.
will be sending the e50 back me thinks !
they can stand the cost.
Well, before being beaten - I would try a few things.
Before GX dev _ I had gppwin and that would work with models not specified ie I could call a FX2n an FX0n and it at least connected and worked.
I have not tried your configuration but maybe test by trying to run the Q in A mode - or tell the E50 it is connected to an A plc.
It's worth a shot :)
with the E50 you may be able to update the firmware and add newer drivers for later PLC's, vist the BEIJERS web site
Hello all. I am trying to program an E50 to operate with an FX1N PLC. Can anybody explain to me how I get a specific block to display when a...
2,222
Just got a new machine in with an E50 display. I decided to suck the project out of it for backup purposes. I've previously only used the E100 and...
1,954
Hi, I am trying to teach myself Mitsubishi e50 hmi, but I cant seem to find an instruction book other than the one that comes with the software. I...
4,977
53
71
