Eaton ELC
raij45
Jul 2017
Missouri
Hi everyone. I am newer to the PLC world. I was trained on mostly Allen Bradley and Rockwell stuff. Long story short. I have never used the Eaton software and set it up. I have the soft/free version. Will that suffice for going in and changing up some micro mechanical switches to proxy sensors? Any knowledge will be much appreciated.
If you're just changing field devices then you don't even really need to change logic do you? Just check that the prox triggers the appropriate input light when activated.
as saffa said, you don't even have to change to logic for that. you could just add some aux relays and invert signal
EDIT:
however, if you can upload program, then just search for every input you're changing and replace it with NO contact if it were NC
I am trying to add to the already written logic. The microswithches that are currently being used do not measure as precise as the proxy I am trying to install. I am not wanting to add anything to this except the proxy switches in a N.C. state.
I know how to do it. My peoblem is the eaton ELCsoft soft ware that is free feom their site is garbage. I was looking for some answers in that end.
I have used the free version of ELC Soft on a couple projects. It's not perfect, but I have a lot less trouble with it than Rockwell software. One job was replacing an AB PLC with the Eaton. The instructions are almost identical to Mitsubishi FX.
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,113
Hello! My name is Richard and I'm hoping to pick the brain-trust here about the Eaton ELC and which Allen Bradley PLC is most comparable. I'm a...
10,608
Need help programming an Eaton PLC, I have a analog add-on module and need assistance on how to program it so i can turn an input on based on the...
1,904
Hi all, Does anyone have any experience with the Eaton PB series PLC? I have one on the way for a project and after digging thru the manual have...
1,909
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
138
