EDS File requirement for LUFP9 v3 (Devicenet to Modbus Gateway)
neerajpuranik
Feb 2006
Bharuch, Gujarat
87
Dear Friends,
I am commissioning a plant having Rockwell Automation PLC communicating on Modbus with Schneider soft starter & Drives. For this we are using Devicenet to Modbus Gateway LUFP9 v3.
I am looking for Following EDS files:
lufp9_100.eds ( Major Revision no.2, Minor revision no.2)
atv71 devicenet v1 3
I googled these files but were not able to get them.
Kindly help
Regards,
Neeraj
Dear Friends,
Kindly help
Regards,
Neeraj
Can anyone from Schneider pl help....
I just had a look on the Schneider site and they do not list an EDS file for this device. You will have to ring their level 2 technical support I believe.
Dear Bob,
Thanks for the reply. I tried with Schneider Customer care also before posting message here but they seems unresponsive. My project is stuck just because of these EDS files as all the drives & soft starters are on communication & EDS files are not available anywhere.
Regards,
Neeraj
Neeraj,
Here is what I got eds file for LUFP9.EDS. I have installed it in rsnetworx via eds wizard. I have not tried it yet. Let us know if it works. OK
Schneider ACB, Soft Starter & Drive on Device net
Neeraj,
Thanks my friend, I will try this & will give you feed back....
One more question for everybody out there.....
Has anybody ever tried Schneider ACB's, Soft Starter (ATS48 with LUFP9) & Drives (ATV71) on communication with Rockwell PLC (Device Net). In my project not a single device is communicating over Device Net. The required EDS files are not available from Schneider. Really having bad time.....
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
100
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
199
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
117
Hi everyone: I went to AB.com, found only firmware, no EDs file showing up. i took a pix of device properties of RSLinx. Thanks
138
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
723
