Electrocraft BSA communications problem
loundeb2
Jul 2010
ny
111
I have an Electrocraft BSA30 drive that I'm trying to communicate with. I have my COM's set up correctly, but I get a port error. I'm using IQMaster 3.24 and a serial to USB adapter. Could the USB adapter be at fault? What else should I check for?
I have the USB recognized as COM 3 and COM 3 selected in IQ Master. All other settings are identical. I've tried BRU emulation, XON/XOFF changes. But still won't communicate.
Are you sure COM3 is available and not being used by some other application? Older versions of RSLinx for example were notorious for not releasing the COM port even though not running.
It could be that IQMaster is so old that it won't work with anything but a real serial port, but see if you can get a different model USB/serial converter. I use one from Staples that works for most of what I need to do, but there are a couple of places where I have to dust off an old laptop with a real COM port.
Hi to anybody; I have here PDM-75 or ElectroCraft 2000 series module; (now is A/B 1398-PDM-75, and work in one of the machines with some...
5,485
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
18
448
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
141
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
185
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple. I have 4 machines...
480
