Enableing DH+ Card On PV+ Screen
WireGuy1950
Jun 2005
Fairport Harbor, Ohio
155
Hopefully a quick (easy) question.
How do I enable a 2711P-RN6 (DH+) card on a PV+ 1250?
I installed it, I think I set the comms correctly in the program, but I get no lights on the card and no communication.
RSView 5.00 CPR 9
PV+ 1250 Keypad
Talking to PLC5/25
Help!
It is my belief that it done in the comms tab in the configuration screen.
The card appears to be a PKTX and the DH+ lights should respond if its connected to a network
We've used the RIO with PV1250+ with success, but you have to config the comm setup using RS View Studio with the embedded RSLinx enterprise software.
RSView 5.00 CPR 9
PV+ 1250 Keypad
Talking to PLC5/25
Help!
see attached image
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
73
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
126
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
108
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
143
